What type of fiber type cross or straight to connect server into x670v-48x port? (Using LC-LC MM 10Gb)
  • Question
  • Updated 1 year ago
  • Answered
I am trying to connect a new server using 10Gb through fiber to my extreme switch x670v-48t. We are using 10G MM SFP SR. The question to connect the port in the switch with the server no patch panel in the middle do I require a straight cable or patch cable (cross)?
Photo of Arturo Ruiz
Arturo Ruiz
  • 70 Points
Posted 1 year ago
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
If you are trying to connect switch to server without any patch panel then we just need fiber cable. There is no straight or cross with fiber cable.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,960 Points 10k badge 2x thumb
Hi Arturo,
you need to "cross" the cable, that is connect the transmitter of each SFP+ to the receiver of the other.
Ram is correct that there is no special "cross" fiber cable, you usually need to cross it yourself.
Erik
