What value do I need for Auto Tx Power Ctrl Adjust on AP 3605?
  • Question
  • Updated 2 years ago
  • Answered
Getting ready to enable Auto Tx Power Ctrl (ATPC) for AP3605. What value do I need for Auto Tx Power Ctrl Adjust? Is this the range up or down it can go or does the min max values set that? Also how does it determine when it needs to adjust power? Any info is appreciated.
Photo of Thomas Randolph
Thomas Randolph
  • 440 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
Hello Thomas,
A typical setting would be to set the Max to the highest setting in the config and Min to the lowest setting (in dBm). The system will automatically try and adjust in that range. It does so by sending packets in the air with a name defined in the RF Domain field. Each access point hears that packet and can determine how to automatically adjust the transmit power of an ap.
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
I'm still confused. What should the   "Auto Tx Power Ctrl Adjust" be set to? Do I just leave it at 0?
Photo of Doug Hyde
You don't need to use the Control Adjust, that can stay at 0.
Thomas Randolph
Is it ok for all APs to be defined with the same RF domain?
Photo of Doug Hyde
Typically it would a name chosen based on location.
Example: Building X, Building Y
Thomas Randolph
Ok. Thanks
