What would be the topology if multiple VNS exist on same interface of identifi controller
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
What would be the topology if multiple VNS exist on same interface of identifi controller, is it same as multiple vlans passing on trunk port ?
Controller will be having one L3 ipaddress on that interface ( for GUI access from network)
I want to  switch traffic locally at AP......
Photo of Saiprasad Rao Rapolu
Posted 3 years ago
Photo of Karthikeyan M
Karthikeyan M, Systems Engineer
  • 546 Points 500 badge 2x thumb
Hi Saiprasad,
Its recommended to use separate Admin interface for GUI access from network.
You may find default topology with B@AP configuration for switching traffic locally at AP. You can make use of that topology.
Extreme doesn't use the term "trunk". Create one topology for each VLAN IDs and assign it to esa0/1/2 or 3. Assume topology as a VLAN with an egress port. While creating B@AP topology assigning controller's physical interface is not needed as VLAN are going to be at AP.
For more info about topologies, Pl read IdentiFi wireless user guide, Chapter 5. Configuring topologies. Link here: https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=c2513a5a-1186-4e25-ae97-dc9e1...
-Karthikeyan M
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
For each scope in DHCP (for each vlan) you need to define the controllers IP, that's all you need to do, after that normal IP routing will do the rest.  Once the AP learns the controller it will remember it, but it's still best practice to define dynamic discovery, this makes for easier adds/moves/changes.
As you say, tagged for ap, untagged for user, is fine, keep in mind when provisioning the AP you will need to define the vlan before deployment; for that reason, often it's easier to do things the other way round, untagged for ap, tagged for user, either method is fine.
OK got it.
But what if there are 2 controllers in availability.how will the above dhcp scope part work.
Does "but it's still best practice to define dynamic discovery" mean not to define controller IP in dhcp scope....
Is the above procedure (dhcp part) applicable even when both ap and controller are in same vlan or not necessary.......
(Edited)
With availability enabled and the default setting of approve all AP's set, then the AP would register on the controller defined, with manual approval enabled, you would see the AP on both controllers and could approve it on your chosen controller (this mode is my preferred configuration as it gives maximum control.)  Additionally, in dhcp options you can specify 2 controllers IP's.
No, it means you should define the controller IP(s) in the scope.
That's correct.
Please see page 111 of the current Wireless user guide for an in depth explanation of the AP discovery process (requires Extreme extranet login) https://extranet.extremenetworks.com/downloads/Pages/WirelessControllers.aspx
ok!   understood
with your method of manual approval, will the ap's failover to the other controller if one of the controller goes down.....
Assuming availability link is up yes, if you have fast failover (FF) enabled, you can see in the availability reports that the AP would have 2 tunnels, 1 active to the home controller and 1 backup to the foreign controller.
