What's the extreme networks equivalent of Cisco's show interface command?
  • Question
  • Updated 3 years ago
  • Answered
Hello,
I'm wondering, is there an extreme networks equivalent to the Cisco command for show interfaces that gives you output results like this?
Example:
  reliability 255/255, txload 36/255, rxload 8/255
Thank you
Photo of Sarah Seidl
Sarah Seidl
  • 1,356 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
There are number of port commands that can be used and they all start with "show port"
  • show port utilization
  • show port stat
  • show port rxerror
  • show port txerror
Based on the output you presented it looks like you are looking for utilization or stats.
Hope this helps!
Sarah Seidl
thank you
Photo of EtherMAN
EtherMAN, Embassador
  • 7,210 Points 5k badge 2x thumb
very confusing Cisco centric command and I cant think of anyone else that has that command.. I would rather be able to ask for what I am looking for then have a cryptic interpretation of "reliability"  Like Patrick says there are many port based commands that are real time where you can get port stats that auto refresh in real time.  Very useful when you are digging around for problems .. just do a show port and tab to get all those commands .... I think you will be happy with what you discover ...
Sarah Seidl
thank you
Photo of Lane, Mike
Lane, Mike, Employee
  • 904 Points 500 badge 2x thumb
I agree with Patrick (and EtherMAN).  If you were really into finding the perfect output, formatted exactly the way you wanted, a python script would do the trick.  You can have the script output any of the various helpful "show port X" commands and then do a little string processing to get the output just right.  Of course, Netsight and other monitoring apps can do the trick even better, while saving the historical data for even more usefulness!
Sarah Seidl
  • 1,226 Points 1k badge 2x thumb
thank you
