when connected via console port getting error as System is in trial for 30 day(s) and this will expire in 7 day(s), X460-48t, EXOS
  • Problem
  • Updated 1 year ago
  • Solved
SW 1 & 2 are showing the following error when using the console port. Can you please advise why this trial licence warning is
appearing and is this potentially service impacting? NOTE: When logging in via SSH this warning is not seen.
SW-01.1 # exit
login:
SW-02.1 # exit
04/04/2017 15:10:41.27 <Info:AAA.logout> User ****** logout from serial
System is in trial for 30 day(s) and this will expire in 8 day(s)
Photo of Somyaranjan
Somyaranjan
  • 150 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,268 Points 3k badge 2x thumb
Somyaranjan,
Please execute "show license" and check the license type. You would get this warning message, if you are running a trial-license and it is about to expire in another 8 days.
Somyaranjan,
could you please share the output of "show license"?
In case, if you have applied a permanent license and if you are still receiving this warning message. We could clear the trial license by executing the command "debug epm clear trial-license".
Note:- This would require a reboot of the switch.
Somyaranjan
SW-01.1 # debug epm show nvram NVRAM Info:
      Current License: 3
      Previous License: 0
      Current Feature pack: 0
      Previous Feature pack: 0
      Trial Expiry Date: 0
      Number of trial license: 0
      Trial Secs: 0
      Checksum: 0
SW-01.2 # sh licenses
Enabled License Level:
        Core
Enabled Feature Packs:
Somyaranjan
There are no trail license running on it... When i logged in via console port i am getting this error, But while logged in via SSH no error observed..
What is the model# of the switch and the EXOS Release running on it?
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
Could the trial license be enabled previously and cleared without the switch being rebooted ?
A reboot is needed after the trial-license is cleared.
Somyaranjan
Hi Oscark, No we have not enabled any license before... If so why we are not getting error while logged in via SSH.
Somyaranjan
SW-01.2 # sh versionSwitch      : 800538-00-02 1333N-41165 Rev 2.0 BootROM: 2.0.1.7    IMG: 15.3.2.11
PSU-1       : PSSW301201A -02 800519-00-05 1333A-40067
PSU-2       : PSSW301201A -02 800519-00-05 1332A-40501
Image   : ExtremeXOS version 15.3.2.11 v1532b11-patch1-2 by release-manager
          on Wed Aug 14 17:43:34 EDT 2013
BootROM : 2.0.1.7
Diagnostics : 5.10
SW-01.3 # sh switch
SysName:          SW-01
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       00:04:96:8B:C3:65
System Type:      X460-48t
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Thu Apr  6 06:51:21 2017
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Tue Sep 17 18:34:53 2013
Boot Count:       6
Next Reboot:      None scheduled
System UpTime:    1296 days 12 hours 16 minutes 27 seconds
Current State:    OPERATIONAL
Image Selected:   secondary
Image Booted:     secondary
Primary ver:      12.5.4.5
Secondary ver:    15.3.2.11
                  patch1-2
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.3.2.11
                  517495 bytes saved on Wed Dec 14 04:31:21 2016
Somyaranjan,
Am suspecting a trial license might be installed in the past and the switch wouldn't have been rebooted after clearing the trial license. Would it be possible for you to reboot only 1 switch and check if it is still logging the following message?
Somyaranjan
Is there any solution apart from this, for reboot i need to check with customer approval and get back to you..
