Where to download legacy firmware (EOS)?
  • 4
  • Question
  • Updated 4 weeks ago
  • Answered
Dear all.
On and off I need specific legacy firmware versions for Enterasys devices running EOS. C-Series, B-Series, etc.
Since we have a new portal, I do not find all the old versions for all legacy EOS products.
Some are there, but not all.
For example C2/3 and B2/3 are missing.
Where to download firmware for these models?
thanks and best regards
Alexander
Photo of aloeffle
aloeffle
  • 980 Points 500 badge 2x thumb
Posted 1 year ago
  • 4
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
I have copies of some old firmwares, do you need a particular version?
I do you have last firmware to B3 switch ?
Photo of dantecl
dantecl
  • 104 Points 100 badge 2x thumb
James, do you have anything 6.51+ for the C3 series?
Photo of Patrick Cotter
Patrick Cotter
  • 60 Points
do you happen to have Motorola RFS6010 wireless controller firmware???
Photo of marcus90
marcus90
  • 116 Points 100 badge 2x thumb
Hi, I'd need the latest version for a B3G124-48P and any necessary intermediate updates. Thank you!
Photo of Ferlira Sllj
Ferlira Sllj
  • 60 Points
Hello good day
If possible the switch of the school where I work corrupted the software and we need a lot of fimware to recover it. I urge you if you can send us the fimware. Our switch is a2h124-24.
My e-mail: fernando.lira@ifpr.edu.br
Sincerely, Fernando Silva lira
Photo of Drew C.
Drew C., Community Manager
  • 40,238 Points 20k badge 2x thumb
We're working on adding these older/legacy products to the portal so that the software is easier to find.
If there's a particular version you need right away, please contact GTAC.
Sorry for the inconvenience.
Photo of aloeffle
aloeffle
That is nice! Thanks. Waiting for your upload :)
Photo of Matt
Matt
  • 186 Points 100 badge 2x thumb
Is there any particular requirement to get these like Cisco has a service contract setup that gives you an entitlement to IOS for a particular device? I am just a home user that is interested in learning about this stuff. I just bought a C2G124-24 off eBay.
Photo of Alexander Stumpf
Alexander Stumpf
  • 60 Points
Same issue here - I'm merely the admin of my home network and recently got four stackable B3G124-24 to play around with at home and would like to upgrade from 6.61.08.0013...
Photo of Brian Anderson
Brian Anderson
  • 722 Points 500 badge 2x thumb
Can't seem to find the download section for the legacy firmware yet, it is still a work in progress?  Thanks.
Photo of Rich Pacheco
Rich Pacheco
  • 964 Points 500 badge 2x thumb
Same here.  Where can I download the C3 firmware?
-Rich P.
Brian Anderson
Good luck.  Please let me know if you find a source.  I opened a case an the GTAC engineer wasn't able to help, he didn't have access to the firmware anymore.
Photo of dantecl
dantecl
Well this sucks...
Photo of Matt
Matt
Hi Drew, Any progress on the old firmware portal? I would love to upgrade my C2G124-24.
Cheers,
Matt.
Photo of Drew C.
  • 37,364 Points 20k badge 2x thumb
Matt, I don't see any of the C2 or C3 software on the portal... at least not by searching based on filename prefixes.
I'll need to find out what I'm able to do here since I found some of the software internally.
Photo of Matt
Matt
Thanks Drew. My current FW on the switch is:
C2G124(su)->show ver
   Model                     Serial #                Versions
C2G124-24         04440141900N      Hw:BCM5695 REV 17
                                                          Bp:01.00.46
                                                          Fw:05.02.01.0006
                                                          BuFw:04.00.31
(Edited)
Photo of dantecl
dantecl
+1 on Enterasys C3 firmwares. I have 2 C3 switches, one on 06.03 and the other on 06.61 and I can't stack them because of this. Would love to upgrade the older one to 06.61 but I can't extract the firmware from the newer switch. Can't open a support case either, gives me some weird error. Help?
Rich Pacheco
Hi Dantecl,
If you stack the C3's, I believe you should be able to copy the code from one to the other using the follwoing command.
set switch copy-fw destination-system <Unit-NUMBER>
and then reset <Unit NUMBER>
Good luck,
-Rich P.
Photo of dantecl
dantecl
Rich,
Pre-6.42 FW will not stack with 6.61, thus can't copy the FW that way. Luckily the one with 6.61 had 6.42 as a backup firmware, booted that, stacked and upgraded the 6.03, then upgraded it again to 6.61.
Was 06.61.11.0006 the latest firmware released for C3 or is there something newer out there?
Rich Pacheco
Glad you got it working.  06.61.11.0002 is the latest C3 firmware I have deployed..
Photo of Matt
Matt
Drew, I think you may have started something here...
Photo of James A
James A, Embassador
I have uploaded my collection of B2/B3/B5/C2/C3 firmware here: http://alfirk.ccgs.wa.edu.au/firmware/
Photo of marcus90
marcus90
I think it was, I managed to get hold of the release notes for exactly that as you can see here:
https://www.dropbox.com/s/hvljrjnw8bg41gs/9038338-19_B3_Firmware_RN_6.61.18.0001.pdf?dl=0
Photo of James A
James A, Embassador
Interesting, July 2017 is well over a year past the advertised end of support. Maybe it was done for a special customer. There's an official G3 (end of support in September 2019) release of 06.61.18 so it probably wasn't too hard for them to build it. What is odd is there's the heritage products section with N-Series and E1 firmware, but no [BC][23] firmware despite those products being newer.
Photo of golebiewsky
golebiewsky
  • 100 Points 100 badge 2x thumb
Here you go:
https://www.dropbox.com/sh/37o4m8ynizexct3/AABtas2VjyUxHbTcDUSOJbXFa?dl=0
I neeeded this firmware as well, I contacted GTAC and they provided me with links, I reuploaded it to dropbox just in case links expire.
Photo of Aleksander Waleski
Aleksander Waleski
  • 62 Points
Great work! However I have a problem downloading "SECURESTACK_B2-402180002-fw.zip" file (403 forbidden). Would you mind looking into that?
Photo of James A
James A, Embassador
Oops, I've fixed the permissions on that file and another one.
