Which all Access points are supported with rogue detector in 4511 series and 4620 AP model series
  • Question
  • Updated 2 years ago
  • Answered
Photo of Nagaraj Kukke
Nagaraj Kukke
  • 222 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Nagaraj
All of the APs support the ability to detect rogue devices.  They can do this while servicing clients on a particular channel or you can set them as a sensor.  For APs like the 4610 and 4620 one radio can be set as a sensor and the other set to either 2.4 or 5Ghz.  The 4511 is a single radio so if it is set to sensor then it can not service users.
I hope that helps
P
Nagaraj Kukke
I need clarification on the basic wips and advance wips, what exactly it differs.
Nagaraj Kukke
I need steps to perform detecting rogue on particulate channel and setting particular radio as a sensor
Photo of Sean Hogston
Sean Hogston, Extreme Alumnus
  • 260 Points 250 badge 2x thumb
This should give you a good explanation of the differences between basic and advanced. To set it up just create the policy and apply it to the controller.
https://www.dropbox.com/s/t399daoo85vfcj0/WIPS_COMPARE_draft.pdf?dl=0
Sean
Photo of Vo
Vo
  • 112 Points 100 badge 2x thumb
Reset default AltitudeTM 4511 Access Point, you can helps me?
Photo of Drew C.
Drew C., Community Manager
  • 37,336 Points 20k badge 2x thumb
I'm going to move this to its own thread to keep this one on topic :)
Please reference the new conversation here: How to factory default an Altitude AP4511?
