Why does flow-redirect not work?
  • Problem
  • Updated 2 years ago
  • Solved
snmp sysName "LAYER2-3_SWITCH"
configure sys-recovery-level switch reset
configure vlan default delete ports all
configure vr VR-Default delete ports 1-5
configure vlan default delete ports 1-5
configure vlan "Default" qosprofile QP1
create vlan "GW_primary"
configure vlan GW_primary tag 10
create vlan "GW_secondary"
configure vlan GW_secondary tag 20
create vlan "Network"
configure vlan Network tag 30
configure vlan GW_primary add ports 1 untagged
configure vlan GW_secondary add ports 2 untagged
configure vlan Network add ports 3 untagged
configure vlan GW_primary ipaddress
enable ipforwarding vlan GW_primary
configure vlan GW_secondary ipaddress
enable ipforwarding vlan GW_secondary
configure vlan Network ipaddress
enable ipforwarding vlan Network
configure iproute add
configure ipforwarding originated-packets require-ipforwarding
create flow-redirect primary_GW
configure flow-redirect primary_GW add nexthop priority 100
configure flow-redirect primary_GW nexthop ping health-check interval 60 miss 3
configure access-list primary_GW vlan "Network" ingress
ACL Policy
entry Network1 {
if match all {
} then {
        redirect-name primary_GW;
LAYER2-3_SWITCH.116 # show iproute
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#d        1    U------um--f- Network    0d:1h:51m:5s
#d    1    U------um--f- GW_primary 0d:1h:52m:4s
#d  1    U------um--f- GW_secondary 0d:1h:51m:47s
#s  1    UG---S-um--f- GW_secondary 0d:0h:5m:45s
LAYER2-3_SWITCH.117 # show flow-redirect "primary_GW"
Name             : primary_GW            VR Name          : VR-Default
Inactive Nexthops: Forward               Health Check     : PING
Nexthop Count    : 1
Active IP Address :
Index    State      Priority  IP Address          Status Interval Miss
0        Enabled    100        UP     60       3
NET_PC> trace
trace to, 8 hops max, press Ctrl+C to stop
 1   0.307 ms  0.358 ms  0.311 ms
 2   *   9.823 ms (ICMP type:3, code:3, Destination port unreachable)
NET_PC> ping
84 bytes from icmp_seq=1 ttl=254 time=9.281 ms
84 bytes from icmp_seq=2 ttl=254 time=6.840 ms
84 bytes from icmp_seq=3 ttl=254 time=3.192 ms
84 bytes from icmp_seq=4 ttl=254 time=2.802 ms
84 bytes from icmp_seq=5 ttl=254 time=3.291 ms
If I remove the static route to the secondary gateway, it still doesn’t work.
As long as I put a default or static route in, I can get to either of the gateways and the desired network behind them, but only one of them.
Photo of Jeff McLeod
Jeff McLeod
  • 220 Points 100 badge 2x thumb
  • Extreme(ly) frustrated
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,214 Points 10k badge 2x thumb
Hi Jeff,
If you look at your other post I believe I answered your question. Please let me know if you have any questions.
Photo of Jarek
  • 2,386 Points 2k badge 2x thumb
what switch (model) and EXOS you have ? I have done this now on my summit 250e and all is working well.
Jeff McLeod
Hey Jarek.  Sorry it took me so long to get back to you, I had a Surface Pro mishap.  So... I'm trying to validate all of my configurations on the virtual appliance, running System type is Summit-PC.  If I can ever get the flow-redirect successfully tested, I will be implementing it on an X460-48p running  Everything seems to work in the virtual lab image, except the nexthop redirect.  I will look at the access-list info that Patrick guided me towards.
Thanks again,
Photo of Jarek
I have done last test on x250e and I think there was xos installed, but I have also x670 with 15.6.3 p1-8 and flow redirect is working ok.
Jeff McLeod
Haha!  Hey Jarek.  It looks like it was the EXOS image I was using in my virtual environment.  I loaded a 15.7.x.x image and everything worked.  Weird thing is; the echos respond with type 3 unreachable, but it gives me a round trip response time. Is this correct?  Is this the way it should work?
Photo of Jarek
I don't like tests on vr environment :).
I prefer test with real hardware. I know that sometimes it is a problem, but vr are good for simple things that don't require hardware.
About the "echo and roundtrip time" in VR... I think we should ask guys from Extreme :)
