Why is the 'Received' Rate(Mbps) a lot less than the 'Transmitted Rate?
  • Question
  • Updated 8 months ago
  • Answered
  • (Edited)
I have the C5210 controller with 3605APs. I'm looking at the 'Reports' and 'Wireless Statistics' and then 'View Clients' per Radio. I noticed under the Received Rate column is quite a bit different than the Transmitted column. Is that normal? I thought clients would be downloading (Receiving) more Mbps from the AP and uploading, sending, (Transmitting) to the AP?
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
Posted 8 months ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
I may be wrong but this looks like the it is from the perspective of the AP. This means the received rate is what the client is sending to it and the send looks like a generic speed based on what type of signal the client is using (a54 or n300).
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
Correct, that is why you'd only see the RSSI in the rx section because it's the signal strenght that the AP has for that client.
Photo of Laura
Laura
Is there a report that shows how many Mbps each client is getting, like a download speed, or how much bandwidth each clients is using? I did download and install the NetSight tool, but still working on setting it up to view some better reports.
You'd run a report for a certain client....
or get even deeper information with Analytics (needs another VM running)....
