Will third party MGBIC-LC04 work with X460-G2-48t-10GE4-Base switch ?
  • Question
  • Updated 1 year ago
  • Answered
Hello, Our customer want to put 100Mb transceivers into sfp+ ports on X460-G2-48t-10GE4-Base switch. Extreme MGBIC-LC04 seems to work. He also bought S/N 10063 100Mb transceivers which doesn't. To avoid additional costs he asks if third party MGBIC-LC04 [or other 100mb MM] will be ok. Could somebody confirm that ?
Photo of Tomasz Lubas
Tomasz Lubas
  • 534 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Roy Noh
Roy Noh, Employee
  • 948 Points 500 badge 2x thumb
It sounds odd that MGBIC-LC04 works.
There was an question about this when x460-G2 was first introduced.
Q. Are 100Mb transceivers supported in the 10Gb ports on the X460-G2?
A. 100Mb transceivers are NOT supported in either the 10Gb front panel ports or the VIM-2x module. 100Mb transceivers are supported in the 24x and 48x 1Gb SFP ports as well as the 1Gb SFP ports on the 24 port switch models.
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
Switch part number's 16701, 16702, 16703, 16704, 16705, 16706 with Front Panel switches  do not support part number - 10063 100FX SFP
Switch part number 16711 with 10Gb SFP+ VIM do not support part number - 10063 100FX SFP
