will turning off radio 2 (g/n) improve a wireless network
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
we want to see if Turing off the second will improve our wireless network. has anyone tried this, and if so, did you see any improvements?
Photo of Laura
Laura
  • 982 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
hi Laura. Why do you think it should help? What issues are you trying to solve?
Photo of Laura
Laura
Another apple tech thinks that too many devices are jumping on the g/n radio, which is slowing everyone else down. He thinks there are too many SSIDs being broadcast and causing interference. He says there are more channels in the 5Ghz band and only 3 in the 2.4Ghz.
The main issue we have is teachers not being able to mirror from their laptop/ipads to Apple TVs. I think it's an Apple issues, not a wireless network issue.
Photo of Robert Styma
Robert Styma
  • 110 Points 100 badge 2x thumb
One thing too look for at is what channels are in use in the area.  The link http://en.wikipedia.org/wiki/List_of_WLAN_channels shows that there is a lot of overlap between channels.  The more overlap, the more interference.  For a given location, if you see strong channels which are numerically close together you are likely to see an impact to wireless network performance.
Photo of Andre Brits Kannemeyer
  • 5,020 Points 5k badge 2x thumb
Hi Laura
As Pala asked what issues are you trying to solve?
By disabling radio 2 you will loose all your 2.4Ghz clients.
They will not be able to connect unless they have a dual band wifi NIC that will be able to connect to the 5Ghz radio 1.
Photo of Laura
Laura
Photo of Raffi
Raffi, Employee
  • 1,598 Points 1k badge 2x thumb
5Ghz band is a better than 2.4Ghz band. There are more non overlapping channels, and less interference from non 802.11 wifi devices ( like cordless phones, Bluetooth, etc ).
If you disable your 802.11 g/n radio, then it will force all users to connect to the 5Ghz band. You could also just not broadcast the ssid on the 2.4ghz radio though.
You could have 5ghz broadcast your apple tv ssid, and use 2.4ghz for other purposes, like guest access.
There is also a band steering feature you could switch on that would push clients that are 5ghz a/n capable to use that band.
It is true that a client roaming back and forth from 5Ghz to 2.4Ghz would not be ideal. You would be able to see if that is happening though from the gui.
Photo of Laura
Laura
Where is the setting to band steer clients to 5GHz?
Hi Laura, as mentioned you will need to ensure that all your clients is capable of 5ghz before disabling the 2.4Ghz.
Is the mirror not working at all or is in intermittent?
If the teachers can not find the mirror device you might be blocking the bonjour protocol on the AP.
Also note that bonjour does not function across a layer 3 enviroment.
You will need to isolate all the bonjour traffic in a Vlan to discover the Mirror device.
You can find detailed guides for this setup on the Hub or extreme support page.
Photo of Laura
Laura
the mirroring is intermittent
Photo of Chris Sherman
Chris Sherman
  • 546 Points 500 badge 2x thumb
I'm assuming that density can also be a concern here.  I definitely have places that I would not want to turn off 2.4 due to poor coverage - i.e. 2.4 has better range that I need in some places and I have so many places to monitor that it would be difficult to see where I could turn it off.  If there's an easy-ish way to tell where I don't need 2.4, please let me know.
Photo of Laura
Laura
I tried turning off 2.4, but then users couldn't get on the wifi, so i had to turn it back on. So that idea didn't work out.
