Wing 5.8.5 Country code AP7532 -xxx WR
  • Question
  • Updated 5 months ago
  • Answered
I have an AP732-67040-WR, The controller see's it fine but the AP LED's are just on, So I know this is invaild country code, Via the CLI I see the following
"error setting country of operation. gb [United Kingdom] not supported on hardware model AP-7532-67040-WR"
It will work under generic 1 -g1 or the others upto g7
What is g1 etc in comparrison to when an AP is set to GB [ United Kingdom ]
Photo of Phil storey
Phil storey
  • 1,254 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Andy Holden
Andy Holden, Employee
  • 1,472 Points 1k badge 2x thumb
To be in compliance with you local regulations, only set the Country Code that matches your region.
Do not utilize the GENERIC X. It may work, but the resultant allowed power and channels may put you in violation of your GB regulations
Phil storey
WR will not accept GB, I only have two of the WR unit, using smart RF, which county is best to use that is same as the UK of very close ? this is output from
ap7532(config)#sh wireless regulatory device-type ap7532 gb
  #   Channel Set Power(mW) Power (dBm)    Placement          DFS       CAC(mins)        TPC
  1    1-13        100       20          Indoor/Outdoor   NA             NA        NA
  2    36-48       200       23          Indoor           Not Required   0         Not Required
  3    52-64       200       23          Indoor           Required       1         Required
  4    52-64       100       20          Indoor           Required       1         Not Required
  5    100-116     1000      30          Indoor/Outdoor   Required       1         Required
  6    100-116     500       27          Indoor/Outdoor   Required       1         Not Required
  7    120-128     1000      30          Indoor/Outdoor   Required       10        Required
  8    120-128     500       27          Indoor/Outdoor   Required       10        Not Required
  9    132-140     1000      30          Indoor/Outdoor   Required       1         Required
  10   132-140     500       27          Indoor/Outdoor   Required       1         Not Required
(Edited)
Photo of Christoph S.
Christoph S., Employee
  • 2,764 Points 2k badge 2x thumb
Hello Phil,
The correct SKU for the UK is AP-7532-xxxxx-EU and not WR.
Per the PMB:
AP-xxxx-xxxxx-EU:
Austria, Belgium, Bulgaria, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, French Guiana, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Malta, Netherlands, Poland, Portugal, Romania, Slovak Republic, Slovenia, Spain, Sweden, United Kingdom
Due to regulatory restrictions and requirement, you should not be using an AP in a country it is not designated for
Regards,
Phil storey
OK, what is the difference RF wise between the EU and WR versions ?
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,116 Points 5k badge 2x thumb
Hi Phil,
the issue here is that there are different regulatory domains - FCC for US, ETSI for EU, ANATEL for Brazil and so on..
In order to follow these regulations we load different driver versions, resp. power tables, to each SKU. US for US and Canada following FCC, EU for Europe countries following ETSI and WR is ready for "rest of word" combining ANATEL etc.
When you use WR with EU country code it obviously does not work due missing power tables. If you use WR with matching country code, you will most probably end up with DFS - TPC incompliancy which might bring you into legal problems.
Such AP won't follow local radar detection / avoidance mechanism and will most probably interfere a lot with neighboring WiFi installations.
Not something we could ever recommend or support.
Regards,
Ondrej
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,272 Points 4k badge 2x thumb
You can see difference for each country/region here:   https://en.wikipedia.org/wiki/List_of_WLAN_channels
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi Phil,
AP-7532-67040-WR AP-7532 dual radio 802.11ac 3x3:3 MIMO Access Point external antenna International version
AP-7532-67040-EU AP-7532 dual radio 802.11ac 3x3:3 MIMO Access Point external antenna EU version
Select only the country in which you are using the device. Any other selection will make the operation of this device illegal. Some Access Points are specifically designed to operate in certain countries (Example; -US for the United States, -EU for the European Union).
Best regards,
Bin
Photo of Vedran Jurak
Vedran Jurak
  • 1,018 Points 1k badge 2x thumb
I would suggest upgrading to 5.9.0 because the release notes state: "WiNG 5.9.0 enables support to configure EU country codes on WR SKU. Downgrading the same device to pre WiNG 5.9.0 release software doesn’t support EU country codes."
Phil storey
didn't know 5.9.0 was out, not on the extreme downloads page
(Edited)
Just upgraded the lab WR AP7532 to 5.9.0.0 and was able to see EU country codes in there:
Phil storey
Hi Christoph
You must have access to un released version of sw, Also if 5.9 was available it would/could caues problems, I see that there is 5.8.6 avalaiable for the 7532 / 71xx  / RFS4000 and 6000 but not for the RFS7000, Is there a plan to release this version 5.8.6 and 5.9 for the RFS7k ?
When is 5.9 going to be released ? or is 5.9 for the VX/NX
(Edited)
Photo of Aviv Kedem
Aviv Kedem
  • 1,554 Points 1k badge 2x thumb
Hi Phil,
WING 5.9 is released in June and available also for VX9000, NX.
As far as I know, RFS7000 is will not have 5.9, as AP71XX.
Regards,
Aviv Kedem
Phil storey
This is sort of on the same subject, I have an AP 7532 the Sticker on the back shows it as an EU model PN:7532I-67030-EU, But when it connects to the RFS is shows it as AP7532-67030- WR
The MAC address on the sticker matches the reported MAC in the RFS, Is there away to correct this?
------------------------------------update-------------------------
I have the answer now to this, Its down to the fact I'm running wing 5.8.5, and the older code supports North America / WR & EU but under the new code its North America & WR which includes the UK, So  symbol days 2 SKU's , Motorola 3 SKU's, and now under Extreme new code back to 2 sku's.
Clear as mud - :-))
(Edited)
