WiNG AP 7522 is not managing with WiNG VX9000 controller?
  • Question
  • Updated 5 months ago
  • Answered
I am unable to manage the WiNG AP7522 to WiNG VX9000 controller, I have checked the firmware version of AP and Controller even though both are having the same firmware AP is not adopting with WiNG vx900 controller
Firmware:AP7522 & VX9000 version 5.9.0.0-033R
Photo of Prabhu.M
Prabhu.M
  • 412 Points 250 badge 2x thumb
Posted 5 months ago
Photo of Andrew Blomley
Andrew Blomley, Employee
  • 792 Points 500 badge 2x thumb
please run the following command of the cli of the access point
show mint mlcp history
this should tell if the ap is look for the controller
is the Ap on the same broadcast domain as the VX ?
could you also send the running config of the controller ??
Andy
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,610 Points 4k badge 2x thumb
Are you sure that the AP7522 is not  'Express' version AP? Can you provide a full part number of the AP7522, you can get that via cli command ' sh version'
Note that Enterprise VX9K will not adopt Express AP
Try setting the controller host on the AP, here are CLI commands :
AP#self
AP(config-device )#controller host xx.xx.xx.xx
AP(config-device )#commit write
Photo of Carlos Assunção
Carlos Assunção
  • 294 Points 250 badge 2x thumb
See if the AP7522 firmware is also uploaded on the VX. Some customer mine has that same issue... the firmare is not by default on the VX.
The VX9000 is supplied into downloadable image images
          image 1) VX9000-5.9.1.4-004R.img
This is the  full image contains all software images for all support access point
          image 2)VX9000-LEAN-5.9.1.4-004R.img
The lean image has had the AP software images removed to reduce the size of the software build
To confirm the software images installed
please use the following command
         show device-image versions
This will list all software versions installed
AP's will also adopt even if the there is a software mismatch.
show adoption status
will tell you if the aps have been adopted, if there is a software mismatch this will show here.
Finally, the VX9000 does not automatically update the firmware
to manually update firmware please use
device-upgrade all
