Wing AP7532 POE consumption
  • Question
  • Updated 3 weeks ago
I wonder what is the watts consumption of AP7532? i cant find this info on instalation guide and ap data sheet.
Regards
Bart
Photo of Bart Bielewicz
Bart Bielewicz
  • 90 Points 75 badge 2x thumb
Posted 4 weeks ago
Photo of Tomasz
Tomasz
  • 868 Points 500 badge 2x thumb
Hello Bart,
The operating current stated in the datasheet is 312mA at 48V DC so it sounds like a little below 15W. But it can be lower with idle state, low load etc.
Hope that helps.
Regards,
Tomasz
Bart Bielewicz
OK thanks Tomasz,
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,554 Points 5k badge 2x thumb
Hello Bart,
you can see selected PoE standad using show wireless ap detail <device name | on RFdomain>
VX# show wireless ap detail on AP
<omitted>
 Power management information for ap7532:
      Power management Mode        : Auto
      Power management status      : 3af
      Ethernet power status        : all up
      Radio power status           : all up
Total number of APs displayed: 1
But better overview you may get on connected switches | PSE (show power status)
Here is example from my lab RFS and two AP7532s
RFS6000# show power status
System Voltage: 53.3 volts
  Guard Band: 32 watts
  Power Budget: 190 watts Power Consumption: 16 watts
  poe device 1 temperature 35C
  poe device 2 temperature 33C
     PORT        VOLTS           mA          WATTS        CLASS       STATUS
  ge1          53.3           151           8.1          4          On
  ge2          53.3           153           8.2          4          On
  ge3           0.0             0           0.0          0          Off
  ge4           0.0             0           0.0          0          Off
  ge5           0.0             0           0.0          0          Off
  ge6           0.0             0           0.0          0          Off
  ge7           0.0             0           0.0          0          Off
  ge8           0.0             0           0.0          0          Off
Regards,
Ondrej
Note:
Radio utilization, Tx power, amount of clients and RF noise around together with number of services running on AP | PD may change the consumption.
You shall never drop PoE switch | PSE provisioning below .3af standard otherwise the AP | PD may not even boot up correctly.
Regards,
Ondrej
Photo of Christoph S.
Christoph S., Employee
  • 3,230 Points 3k badge 2x thumb
This off of the AP label itself:
Input rating:
12VDC - 1.25A so 15W
48VDC - 0.375A (POE) so 18W
Regards,
Chris
Bart Bielewicz
Very informative, thanks all for input.
