WiNG captive portal re-authentication timeout
  • Question
  • Updated 2 years ago
  • Answered
I have setup a captive portal on a VX9000 and I noticed that every day the user has to re-enter the username and password. Is there a way to remain authenticated for as long as the user is valid?
Also is there a way to un-authorize a certain user from the captive portal?
Photo of gluo
gluo
  • 708 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 6,102 Points 5k badge 2x thumb
Hello Konstantinos,
based on your Captive Portal design you may either use access time value / timeout
Or if it is driven by RADIUS (internal) you may change RADIUS group attributes
If you want to de-authenticated Captive Portal users you may do it through Statistics - Captive Portal.
Please find Captive Portal How to Guide under this link for more details.
Regards,
Ondrej
Photo of gluo
gluo
Thank you for the swift reply!
Photo of gluo
gluo
Hi again,
I have one more question.
It seems that the maximum amount of time a captive portal guest can be inactive (meaning not connected to the wireless network) without the session to timeout and have to re-authenticate can be 24 hours . Is there any way to set it to more than 24 hours?
This would allow clients to remain connected over the weekend and not have to re-authenticate each Monday for example.  Or maybe there is another way?
thank you in advance.
Hi Konstantinos,
I setup scenario with AP adopted to a controller when AP had Captive Portal service and controller ran RADIUS service.
Captive Portal configuration as follows:
captive-portal RADIUS
  access-time 10
  inactivity-timeout 60
  simultaneous-users 1
  <omitted>
  use aaa-policy RADIUS
  bypass captive-portal-detection
  <omitted>
WLAN configuration as follows:
wlan RADIUS
  bridging-mode local
  encryption-type none
  authentication-type mac
  use captive-portal RADIUS
  captive-portal-enforcement fall-back
Then connecting to SSID I see in logs that system first tries to authenticate client against AAA / RADIUS and then failover to Captive Portal
Then successful authentication via Captive Portal pages against same RADIUS server
So in theory this will work fine as you see first attempt goes to RADIUS.
You might noticed a problem though - AAA policy asks to authenticate user 38-F2-3E-18-5B-04
This is result of having authentication method MAC.
So here we go with a fork:
  • either you have to create a user database based on clients' MAC addresses instead of username and password
Problem here is that using authentication we need to send a username to question database. With MAC based authentication we use MAC as one and do not actually link it with a RADIUS user account provided through Captive Portal credentials fields. However it works as correctly, it is not designed to be used with anything else than Guest registration.
Regards,
Ondrej
EDIT: Just checked RADIUS group policy for timeout options and I have some bad news - it is also limited to 86400 seconds
However RFC2865 does specify its maximum as 32-bit integer, we have limitation for a day in WiNG
(Edited)
Photo of gluo
gluo
Hi Ondrej,
Thank you for your detailed answer and testing. Really helpful information, good job!
My use case is site visitors that are being handed out pre-printed vouchers with username/passwords in order to authenticate and being able to access the WLAN, so there is no previous knowledge of the MAC address, hence the first fork does not fit, please correct me if i am wrong.
About the second fork, I can not download the document because it takes my to your sharepoint cloud server. So I need your aid with the following:
1. Does self registration allow anyone to access the WLAN? (That would be a problem in this case)
2. Is it possible to provide a username/password (CP) and then the user enter his own mac (AAA)?
If the second is possible then the inactivity timeout of the RADIUS holding MAC addresses, would not be a problem since it happens automatically.
Hi Konstantinos,
here is new link - I probably checked wrong access rights.
Anyway, you are right about the self-registration. This allows everyone to access under condition client finishes registration. Might be OAUTH, Click&Tell etc...
If you provide the username / password you will capture MAC automatically as it is being recorded by Captive Portal. However, here we are hitting the limit of 86400 seconds.
Then, yet another issue - if you select AAA policy to be used here, it does not receive any EAP ID from client - remember this is not set on client!
Any authentication method (other than MAC) requires client to be induced in identification. But with open network client does not provide any.
So in the end authentication request will failover back to Captive Portal.
I am afraid there is only solution for this use case - externally hosted custom pages capturing the MAC used with an CP voucher and creating a fake RADIUS guest user account based on the MAC address - quite demanding one.
Regards,
Ondrej
Photo of gluo
gluo
Thank you Ondrej. Your help was enlightening!
Glad to help :-)
Regards,
Ondrej
