Wing Controller SSL Import
  • Question
  • Updated 3 months ago
  • Answered
  • (Edited)
Has anyone had any success importing SSL certificate from GoDaddy or other 3rd Party into Wing Controller?
We are able to import from a local CA but no 3rd party certs will work.
Photo of Matt Compton
Matt Compton
  • 90 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 4,968 Points 4k badge 2x thumb
Hello Matt,
Can you make sure you import the whole chain?
See this article on GTAC Knowledge Base
< https://gtacknowledge.extremenetworks... >
Regards,
Ondrej
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
Here's a non-mobile link to the same article :)
https://extremeportal.force.com/ExtrArticleDetail?n=000014936
Matt Compton
Yes. I import the whole chain. everything works fine until i get to importing the actual certificate.
The Root, Intermediates upload fine at first when creating the trust. When uploading the server cert I get an message saying that the private key doesnt match.
If I create the CSR from the controller itself, and get the certs signed, do the upload the the same way, I get a message saying that the private key isnt found in the datastore, even though the system creates it itself...
If I do from Microsoft CA, The upload works correctly as expected. Just not sure what the catch is with doing from 3rd Party CA's
Matt,
I suggest to open a case with GTAC sonwe can take a look.
There might be something small missing
Regards,
Ondrej
Matt Compton
I did and its been over a week troubleshooting with engineers. So I thought I would check here if someones actually been able to get this to work.
Matt,
I managed to install Comodo certificate without issues
Let me know the case number and I'll take a look if not sorted yet.
Regards,
Ondrej
