Wing express AP 7502 initial configuration
  • Question
  • Updated 4 months ago
  • Answered
Hi Team,
Actually, I am doing initial configuration with individual AP and PC without a controller,
So, what are the steps needed to configure AP without a controller, only IP setting?
Regards
NIyas P
Photo of Niyas
Niyas
  • 1,092 Points 1k badge 2x thumb
Posted 5 months ago
Photo of Andy Holden
Andy Holden, Employee
  • 1,492 Points 1k badge 2x thumb
Hi
The initial step will be lo log into the WEB INTERFACE.
The APs ge1 port is configured as an ACCESS port utilizing DHCP to obtain an I/P
Wing Express does not allow CLI configuration updates.
Once you are in the AP, you can then set it to a Static I/P
Depending on the release, there is a configuration guide that will lead you through a basic configuration
Photo of Christina M
Christina M, Alum
  • 1,728 Points 1k badge 2x thumb
Hi there,
Here's the Quick Reference Card for this AP: https://documentation.extremenetworks.com/ExtremeWireless/AP7502_WALLPLATE_IG_MN001385A01_REVD_EN.pdf
The relevant section is Basic Ap-7502 Configuration:
To provide the Access Point with a basic configuration and access WiNG management functions, open a browser and enter the IP address printed on the  serial label on the Access Point: https://<IP address of Access Point>.
Log in to the system using the default username (admin) and password (admin123).
1. On the Configuration -> Basic Settings screen, enter the AP Name and Country Name.2. On the  Configuration -> Wireless screen, enter the desired Name, SSID, Security, and WPA2 Key parameters.
Also, here's the latest WiNG Express User Guide. AP Configuration starts on page 9: https://documentation.extremenetworks.com/ExtremeWireless/WING_EXPRESS_5.8_UG_MN002231A01_EN.pdf
Hope that helps!
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 2,258 Points 2k badge 2x thumb
If running WiNG v5.9 on Express AP, the following link is the latest Express User Guide for v5.9.x:
https://documentation.extremenetworks.com/WiNG/5.9.0/9035125_WiNG_Express_5_9_UG.pdf
