WING5 with Juniper switches
  • 2
  • Problem
  • Updated 1 week ago
  • Solved
Hello All,
At last few years when i installing WING5 products with Juniper switches it seems layer2 MINT is blocked by switches withouts any log in the switch.
So I set up a layer 3 adoption to workaround this issue, but it it seems we're running away from the problem and we need some recommendations in this case.
I still want to use a default layer2 adoption method.
How we can make it work with Juniper switches?
Regards,
Aviv
Photo of Aviv Kedem
Aviv Kedem
  • 1,714 Points 1k badge 2x thumb
Posted 12 months ago
  • 2
Photo of Daniel Fraile Villalba
Daniel Fraile Villalba, Escalation Support Engineer
  • 790 Points 500 badge 2x thumb
Hello Aviv,
Per the release notes:
When using Juniper ex2200-24p-4g or related models when connecting WiNG Access Points – either disable IGMP snooping on the Juniper switches to ensure AP adoption or configure firewall policy filter that will allow the flow of traffic to specified destination-mac-address –
01:A0:F8:00:00:00/48.
If you have any further question let us know! Have a nice day!
Photo of Aviv Kedem
Aviv Kedem
Hello Daniel,
Thanks a lot.
(Edited)
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,962 Points 1k badge 2x thumb
Simply change switches: Summit X440-24p does a great job..
Photo of McNulty
McNulty
  • 94 Points 75 badge 2x thumb
I'm experiencing the same issue, thanks for the info.
I will add that you can also manually configure mint-over-ip links between APs. I did this beacuse I didn't have control of the switches.
I added the manual mint link commands for all APs in the ap profile so it got inherited by all.
