Wireless AP manual firmware update with internal memory format?
  • Question
  • Updated 7 months ago
  • Answered
I am aware of how to manually upgrade AP's via SSH and have done so many times.  A customer has raised a concern that any manually created files on the internal memory of the AP remain in place even after upgrade.  In some case I would imagine this should be useful, but in our case I am trying to find out if there is an option to upgrade the firmware on an AP and perform a full data wipe as part of the process.  I think the concern here is that AP's can potentially be filled up with Junk and affect their performance or that maliciuos files on internal memory could impact security.  An option to do a full format upgrade across the estate could provide a clean slate and if thats an available option I suspect many customers would benefit.
Any thoughts anyone?
Thanks
Photo of Rich
Rich
  • 230 Points 100 badge 2x thumb
Posted 7 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
Can you explain more on this.... "manually created files on the internal memory of the AP remain in place even after upgrade"?
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
Hi Rich,
I don't chek this if created files get deleted after FW update but I assume if the customer is requesting than likely not..
But I don't heard about something like this and assume there is also not possible to set the AP to his factory file setttings .
The best what I could suggest  would be to change the AP ssh password so that not much people have access to it?!
Regards
Umut Aydin
Photo of Rich
Rich
Hi Doug,  If you SSH to an AP and use "vi" editr to create a script and save, it will remain as a file in the root directory and show up using an "ls".
This file will remain in place following an upgrade either manual or pushed from the wireless controller.
Hope this explains it a little better.
Thanks
Photo of Joshua Puusep
Joshua Puusep
  • 2,274 Points 2k badge 2x thumb
Hi Rich,  Just out of curiosity, what are you using the local scripts for?  Perhaps you could execute the same functions from extreme management center without having to keep anything on the AP itself.
I haven't tested this and it's not exactly what you're asking for, but i'd think that issuing a factory reset "cset factory" would wipe the files.
Photo of Doug Hyde
Hello Rich,
The shell on the ap is for service personnel to support debugging when issues arise, it's not for general use. That is why we do not maintain any guides for it. Like Joshua pointed out, perhaps you could use ExtremeManagements script tool to pull out the information you are looking for.
