Wireless Channel inspector
  • Question
  • Updated 1 year ago
  • Answered
Hi Community
The "Channel Inspector" in the controller reports is pretty cool.
I do have a question regarding the accuracy of the channel rating provided.
Below is a screenshot of one AP.
Channel 108 is marked as being the best channel to user, but this is the only channel with Co-Channel interference.
Surely channel 100 will be the best option to use.
Your comments would be appreciated.
Thx
Andre
Photo of Andre Brits Kannemeyer
  • 5,214 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Philipp Tittmann
Philipp Tittmann
  • 774 Points 500 badge 2x thumb
Hi Andre,
in my opinion the ranking is just a kind of warning level. This makes more sense to me and my experience so far.
Edit: Ok i found the description for the ranking, and you are absolutly right. So because of this, it doesn`t make any sense to me right now :)
Regards
Philipp
(Edited)
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,588 Points 5k badge 2x thumb
Hi Andre
We could look at this as a support issue if you open a case, it would be good to get the tech supports, AP logs (from the AP's on the channels listed) and a simple diagram to show AP locations.
-Gareth
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Yes it's weird...
result if you click on channel#36 = 3x adjacent channel because AP3801i-1 is on channel#44+1
result if you click on channel#44 - 3x co-channel also AP3801i-1
I'd say that isn't correct - the same AP is listed as adjacent (OK) and also as co-channel (NOK).
With that information let's talk about your screenshot - the AP is set to 20MHz on channel#108.
I assume if you click on channel#104 and 112 it will list one AP on each channel = adjacent = OK
The result shows the view of the AP on channel#108 so even if you switch to channel#100 that would mean that you've once again one AP on a adjacent channel = 104.
So the current channel is as good as channel#100 BUT #108 in my opinion should have more * as channel 104 and 108.
Photo of James A
James A, Embassador
  • 6,982 Points 5k badge 2x thumb
I'm a bit confused by this output:
It's from a building where all the nearby APs dynamically selected channel 36. What I don't understand is why channels 157-165 are ranked so low. Also the star rating doesn't seem symbolic, it really just acts as a sort order than a measure of channel quality.
