wireless clients are moving to undesirable SSID
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
I have setup consists of NAC, LDAP and wireless controller with several SSIDs. Two SSIDs are 802.1X authentication mode based on LDAP through NAC and other two SSIDs are simply pre-shared key based.
The problem that the smartphones which should connect using 802.1x based SSID they are moving sometimes to another SSID while roaming from AP to other or/and when connected again after losing the coverage.
Is there a way to enforce those users to connect to desirable SSID automatically. But other than deleting undesirable SSIDs from those phones because they are needed sometimes.
It might be silly case! but it is end user' request :(
Photo of Husam
  • 1,272 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 19,896 Points 10k badge 2x thumb
It's all client driven unfortunately. If you have enough coverage it should not be an issue but I know that's not always the case.
