wireless clients not getting dhcp
Lorielee_Jacint
New Contributor II
Clients connect to a Guest SSID which is set to VLAN13. We have another SSID connected to VLAN1. Clients trying to connect to the guest SSID do not get a DHCP address. We have the router serving DHCP addresses. We have VLAN1 set to local and VLAN13 set to tunnel. What are we missing? We tried bridging the two via local and tunnel, but we get the same result. Any help would be appreciated.
13 REPLIES 13
Lorielee_Jacint
New Contributor II
f19e04440c4840629628d844311d1f5d_RackMultipart20180802-107212-1qkr70-guest_issue_inline.jpg
Lorielee_Jacint
New Contributor II
We are having a Layer 2 issue.
Lorielee_Jacint
New Contributor II
Switch side, it is yes. We have statically setup a device on the VLAN13 and it works, but when we go DHCP devices get a 169 IP.
I put in a picture that my network guy I'm working with created. I understand it was conflicting info earlier, but things were lost in translation. I was under the impression that it worked statically, but that was incorrect on my part. Below in the pic is the layout.
