wireless controller first login c5210
  • Question
  • Updated 3 years ago
  • Answered
Hi all
I got new wireless controller C5210. I need to do the first login. I have connected my laptop to port eth0 of the controller. my laptop IP is 192.168.10.10. I can not login the controller at the default IP which should be 192.168.10.1 and port 5825 neither can't ping this IP.
anyway have advice for such case.
Thanks in advance,
Husam
Photo of Husam
Husam
  • 1,272 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Alexandr P
Alexandr P, Embassador
  • 12,042 Points 10k badge 2x thumb
Hi, Husam!
You have to connect to Mgmt port (192.168.10.1), but not in eth0.
After first connect you can configure Topologies (ports) and other.
Thank you!
Photo of Husam
Husam
Hi AlexandrP,
Thanks for your response. I am connecting my laptop directly to port eth0 which according to quick reference is the mgmt port. I am not connecting to asa0 nor asa1
is there any other management port?
Thanks in advance,
Husam
Photo of Alexandr P
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
(Edited)
Photo of Husam
Husam
my laptop is connected to port marked C in quick reference, is it right ?
Photo of Doug Hyde
If it still does not work you can try to attach a console cable directly to the controller.
 https://gtacknowledge.extremenetworks.com/articles/Q_A/Using-the-Console-Port-on-the-IdentiFi-Wireless-Appliance-C25-C4110-C5110-and-C5210
Please note, the fans will spin even when the appliance is offline so make sure the appliance is really powered up.
Photo of Doug Hyde
ok, try the console cable to see if you get any output...
Photo of Husam
Husam
I got this output!!! it is new to me!
Photo of Husam
Husam
Also below output
Version 2.00.1201. Copyright (C) 2010 - 2012 American Megatrends, Inc.          Bios Version: SE5C600.86B.01.08.0003.022620131521
BMC Firmware Version: 1.17.4207
SDR Version: SDR Package 1.09
ME Firmware Version: 2.1.7.112
Platform ID: S2600GZ
System memory detected: 16384 MB
Current memory speed: 1333 MT/s
Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz
Number of physical processors identified: 2
AHCI Capable Controller enabling 2 ports of 6Gb/s SATA
SAS/SATA Capable Controller configured with 4 ports in SATA mode
USB Keyboard detected
Press <F2> to enter setup, <F6> Boot Menu, <F12> Network Boot
Photo of Husam
Husam
also this output:
FI Shell version 2.00 [4.632]Current running mode 1.1.2
Device mapping table
  blk0 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part1,Sig76E8F4C6)
  blk1 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part2,Sig76E8F4C6)
  blk2 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part3,Sig76E8F4C6)
  blk3 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part4,Sig00000000)
  blk4 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part5,Sig00000000)
  blk5 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part6,Sig00000000)
  blk6 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part7,Sig00000000)
  blk7 :HardDisk - Alias (null)
        Acpi(PNP0A03,0)/Pci(11|0)/Pci(0|0)/VenHw(Unknown Device,80000000)/HD(Part8,Sig00000000)
  blk8 :BlockDevice - Alias (null)
Press ESC in 1 seconds to skip startup.nsh, any other key to continue.
Photo of Doug Hyde
what happens when you press enter, will it get you to a prompt?
