Wireless Controller seems not tag vlans
  • 2
  • Question
  • Updated 10 months ago
  • Answered
Hello
we want to use vlan tagging via wireless controller. The Management vlan should be untagged and the Client should be tagged.
the ExtremeWireless (IdentiFi) has the option to tag vlans. But all traffic falls into the untagged (native). An Extreme access point is connected to a Cisco Switch. Is there a Special configuration nessesary for the Cisco Switch to build a trunk to the access point?
Thanks for any help.
Greetings
Photo of David
David
  • 90 Points 75 badge 2x thumb
Posted 11 months ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,316 Points 20k badge 2x thumb
No, there is nothing special, you just need to do it right.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
The B@AP topologies for users just need to be tagged, the port the ap is plugged in to should be tagged as well for the same VLAN ID.
Photo of Doug Hyde
Photo of David
David
@Hyde: This configuration is done for the Client traffic. The Management port for the access point should be in another vlan. The port on the Cisco Switch is configured as trunk with the client vlan id as trunk vlan and the Management vlan as native vlan (untagged). Is this correct?
Photo of Doug Hyde
Correct.
