Wireless Controller (v2110) cluster separation ?
  • Problem
  • Updated 7 months ago
  • Not a Problem
Team,
We need to remove the Wireless controller V2110 from a cluster.
Could you please suggest me any article or documents to achieve this .!!!
Thanks in Advance.!!!
Boopathy Chnadrasekar
Photo of Boopathy Chandrasekar
Posted 7 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,036 Points 20k badge 2x thumb
Do you mean a controller availability pair or mobility group?
What software version is running on the controller?
-Ron
Why do you want to remove the controller - just to better untstand the issue.
we are using 2 Wireless controllers in a Cluster (v2110) & along with 180+ wireless AP 3825i and we are planning to upgrade the controllers into v9.21.19.
(Current version : 9.21.07 )
Our plan of action is like :
- to separate the controllers from the Cluster and going to upgrade only one Controller into 9.21.19.
( Note : Each controller registered with 80 Wireless AP 3825i. )
So, we need to remove the controller from the Cluster.
Thank you ,
Boopathy Chandrsekar
There is no need to remove the cluster - you'd only upgrade one controller and the APs on it.
But if you'd like you just set availability back to stand-alone in the GUI > controller > administration > availabliity.
That would mean you don't have any redundancy in case of a controller outage.
