Wireless controller why there is AP suuport per appliance and AP support in standard mode
  • Question
  • Updated 3 years ago
  • Answered
Can anybody tell me what is the difference between this terminology
1) Total AP supported per Appliance   2) Total AP supported in Standard mode.
why total AP supported in standard mode showing exactly half of the AP supported per appliance
CAPACITY                                                     C25      C35      C5210
Total APs supported per appliance                100      250      2,000
Total APs supported in standard mode          50       125      1,000
Photo of SB
  • 202 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Alexandr P
Alexandr P, Embassador
  • 11,632 Points 10k badge 2x thumb
Because appliance is 2 Controllers in cluster and they can share or double AP capacity.
1 C25 hardware support 50 AP * 2 = 2 C25 - 100 AP.
Thank you!
Photo of SB
It means - C-25 support only 50 AP when it used in standalone mode..
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 2,280 Points 2k badge 2x thumb
Hello Sushant . As Alexander mentioned, you can pair two appliances (hardware or virtual controllers) . Or you can use standalone appliance . In standalone mode you can connect X amount of AP's . In paired mode you still will be able to connect X amount of AP's to each controller , but in case one of the controller is gone (e g lost network connectivity , upgrading , rebooting or failed ) all it's AP's will fail over to the one controller which stays alive . In this case controller will support 2xX (twice) amount of AP's ; there will be no functionality/features lost or anything . Each Extreme Controller designed and tested with the double capacity (in terms of number of AP's , number of connected Clients per controller)  in mind for that purpose.
If you pair diffrent types of appliances ,e.g. one controller is C25 which can have 50 AP's and one controller is V2110 which can have 250 AP's , then in case "bigger" appliance fail the "smaller" appliance will take only first 50 AP's due to limitation , therefore it will serve 100 AP (50 locals and 50 foreign) .
