Wireless Planner report fails
  • Problem
  • Updated 4 weeks ago
  • Solved
After completing a plan using an imported jpeg floorplan and auto-placing APs, I save the plan and select Generate Report. I have the option to choose pdf or docx. When I choose either the report fails to generate.  Has anyone else run into this issue?
Photo of Jeff Roberts
Jeff Roberts
  • 212 Points 100 badge 2x thumb
Posted 1 month ago
Photo of Paulo Francisco
Paulo Francisco, Employee
  • 1,534 Points 1k badge 2x thumb
We have identified and corrected the issue. Report generation is working again.
Apologies for the delay in acknowledgment. Initially thought it was going to be a quick fix with a straight "Fixed!" status but took longer to correct. Thanks for the notification and apologies for the inconvenience.
