Wireless Planner / RF Planner login Fail
  • 2
  • Problem
  • Updated 1 month ago
  • Solved
Hi Community
I have an issue logging into the RF Planner tool.
My credentials worked fine last week but this week it claims "Invalid credentials".
I have been in contact with another two engineers and they are experiencing the same issue.
Both of them could still login last week but today they also recieve "Invalid Credentials"
Does anyone else have the same issue with the tool??
(I am desperately needing to complete some plans) ;(
Photo of Andre Brits Kannemeyer
  • 5,214 Points 5k badge 2x thumb
Posted 12 months ago
  • 2
Photo of Francois Scheun
Francois Scheun
  • 520 Points 500 badge 2x thumb
Hi guys
Further to the above the portal does not allow for country selection prior to login. Login attempt with previously working credentials fails for me too.
Need to access this urgently.
Regards,
Francois
Photo of Jason
Jason, Employee
  • 3,608 Points 3k badge 2x thumb
Andre and Francois,
I had problems yesterday too but it is now working for me.  Can you let us know if this is still not working?
Thank you,
Jason
All working yes thank you Jason
Photo of Thomas Wu
Thomas Wu
  • 90 Points 75 badge 2x thumb
Hi, Community,
I have an issue with logging into the RF Planner Tool. My credentials worked fineI last hour but it claim " invalid credentials" when I try to login now. it has any use or number of created plan limitation ?
Regards ,
Thomas
Photo of Uziel Blanco
Uziel Blanco
  • 74 Points
I have too the problem with "invalid credentials"  :(
Photo of Jason
Jason, Employee
Thomas and Uziel,
This is being looked into and we will update this thread with more information as soon as possible.
Thank you,
Jason
Photo of Jason
Jason, Employee
Thomas and Uziel,
I believe access is working, I have been able to login, can you please try again and let us know if you still cannot log in.
Thank you,
Jason
Uziel Blanco
  • 74 Points
Si, ayer en la noche pude por fin acceder a la plataforma correctamente, pero parte de la información que ya había guardado se perdió.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,846 Points 20k badge 2x thumb
Google translate...
Yes, last night I could finally access the platform correctly, but part of the information I had already saved was lost.
Photo of Thomas Wu
Thomas Wu
Hi Jason,
it's work and I used it to create RF plan for my project yesterday.
Thank you.
Thomas
