Wireless planner tool issue
  • Problem
  • Updated 4 months ago
  • Solved
Hello, all!
Upload image.
1. Draw boundary.
Trying Set scale and receive error - Floor size is out of bounds.
2. Set scale.
Trying to draw Boundary and receive error - Boundary size is out of bounds.
Any ideas?
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Posted 2 years ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,760 Points 5k badge 2x thumb
Hi Alexandr
How large is the area in square metres you are using as your plan?
-Gareth
Photo of Alexandr P
Hello, Gareth!
96x177 meters.
Thank you!
  • 5,670 Points 5k badge 2x thumb
Thanks - I'm checking into that and will let get back to you as soon as possible.
Hi Alexandr
The current limit is 10000 square metres, can you subdivide the area somehow?
-Gareth
Photo of Alexandr P
Thank you for information!
I'll try.
Photo of DINESH KUMAR
DINESH KUMAR
  • 60 Points
hi
how to load image on planner
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Take a look in the below image....
On the right side you'd see my location tree with Country Austria, location Vienna
 and per location you'd create floors (EG in my example).
Then on the floor level in the lower left corner you've th elink for image upload.
