Wireless - SSID grey'ed out ?
  • Question
  • Updated 3 years ago
  • Answered
I have an issue where under the access points, if I want to add an SSID to be broadcasted from an AP - it is grey'ed out.
Previously, it would be clickable, but after a page refresh, it would revert back to being unclicked.  So we upgraded the V2110 (v.9.15) and migrated it to Hyper-V.
Now the option to enable an SSID on an AP is grey'ed out ?  any reasons for this ?
*the SSID and AP are not part of a SITE, nor are the default configuration templates imposed.
thanks !
Photo of Dewald Botha
Dewald Botha
  • 674 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,588 Points 5k badge 2x thumb
Hi
Is the AP in a load group?
Are all the components (vns, wireless service etc) enabled?
-Gareth
Dewald Botha
Hi Gareth,
Yes they are - based on their physical locations.
Yes again - these are APs that are deployed over a large site, where only some of them do not want to enable a certain SSID over radio 2 for example, or for that matter, disable it.
Just curious as to the reason behind this, could it be the fact that the load-group overrides it ?  But then, why can't I enable/disable the SSID on the AP - or am I missing something ?
thanks.
Hi Dewald
Yes the load group over-rides selection of wlan service via the AP wlan assignement tab of the GUI.
See: https://gtacknowledge.extremenetworks.com/articles/Solution/Trying-to-remove-a-WLAN-service-from-a-radio-but-the-check-box-is-grayed-out
-Gareth
Dewald Botha
Thanks Gareth !
