Wireless V2110 Station Event Detail
  • Question
  • Updated 2 years ago
  • Answered
Good Morning, i want to know the meaning of Voice "ROAMED = NO " in attached file.
We have some issue with Ascom I62 / OpenStage WL3 and Acess Point 3805 - 3965i.
Thank You
Giuseppe
Photo of Giuseppe Montanarella
Posted 2 years ago
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Giuseppe,
Are you referring to "Roamed: No" from the screenshot provided under station current information?
Regards,
Nathiya M
Yes, is correct, as i said before, I have some issue with the Ascom I62 and AP3805/3965i
Giuseppe
Hi Giuseppe,
That means, whether the client roamed to another AP or stationary.
Could you please explain the issue with Ascom I62 and AP3805/3965i?
What is the code version running on the controller?
Regards,
Nathiya M
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,226 Points 50k badge 2x thumb
Are you sure - I think it's roaming to another controller in a mobility group = inter-controller roaming.
Or to be more precise... it show whether the client is local or foreign from the POV of this controller.
No = local
Yes = foreign
The version of controller  is V2110-10.21.02.0017
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
Hi Giuseppe,
without having much info..
a quick test if you always  see the issue ..means if you can reproduce the issue at will...
then look on which AP the ASCOM is connected and on which radio and change the DTIm settings from 5 to 2 on the AP config( advance button) and look if you see immediately any improvements.
Additioanlly I would recommend to update to 10.21.03.
Regards
Umut Aydin
OK, I changed the value of DTIM from 5 to 2..but sometimes we have the same Issue.
So I changed the radio frequencies from 2.4GHZ to 5 GHZ. In your Opinion is better to put static channel or automatic channel, the same thing for Power, better static or automatic ?
thanks
Giuseppe
Photo of Umut Aydin
Static is recommended.
Rgds
-Umut
