Wireless WM3600 and AP4620 roaming problem : Client IP 0.0.0.0 when roaming from an AP to another
  • Problem
  • Updated 5 months ago
  • Solved
Hallo,
this is my firt post on this community.
I have a problem with a WM3600 system (2 in cluster) and access-point AP4620 when a device roaming from an AP to another. The client in dhcp mode acquire the correct IP when associated to the first AP and all ok; when the device roam to another AP, the client info report an IP 0.0.0.0
This is the syslog report of the roaming problem :
AP1 - AP1 %DOT11-6-CLIENT_ASSOCIATED: Client '90-68-C3-49-F0-BC' associated to wlan 'POLI_SMART' ssid 'POLI_SMART' on radio 'AP1:R1'
AP1 - AP1 %DOT11-6-CLIENT_INFO: Client '90-68-C3-49-F0-BC' IP address '192.168.104.2', bssid '00-04-96-6C-52-D2' of radio 'AP1:R1' signal-strength -69dBm
AP1 - AP1 %DOT11-6-CLIENT_DISASSOCIATED: Client '90-68-C3-49-F0-BC' disassociated from wlan 'POLI_SMART' radio 'AP1:R1': roam detected (reason code:8)
AP2 - AP2 %DOT11-6-CLIENT_ASSOCIATED: Client '90-68-C3-49-F0-BC' associated to wlan 'POLI_SMART' ssid 'POLI_SMART' on radio 'AP2:R1'
AP2 - AP2 %DOT11-6-CLIENT_INFO: Client '90-68-C3-49-F0-BC' IP address '0.0.0.0', bssid '00-04-96-90-B2-B1' of radio 'AP2:R1' signal-strength -47dBm
Can you help me ?
Thank
Photo of Grossi Nicola
Grossi Nicola
  • 100 Points 100 badge 2x thumb
  • confused
Posted 5 months ago
Photo of Daniel Fraile Villalba
Daniel Fraile Villalba, Escalation Support Engineer
  • 724 Points 500 badge 2x thumb
Hello Nicola,
Where is the DHCP server running and which activation criteria is configured? Is that SSID tunneled or locally bridged?
Grossi Nicola
Add some info
In this condition the Wireless Firewall Policy drop all traffic, but if i disable the policy the traffic is ok.
The SSID is tunneled
The wlan is a wpa2 pks
The DHCP in a win2012 server (dhcp replay)
There is a radius for the mac-address authentication
Hello Grossi,
Please try to change the SSID's bridging mode into local and check the status.
Hope this will help.
Grossi Nicola
Thanks for the suggestion but it is not possible; only the wm controller is connected to the other LAN services (RADIUS, DHCP, DNS, etc.); the access point is connected (vlan) to the controller only.
Grossi Nicola
Solved :
In the WLAN configuration, if this parameter il checked the problem is present
