wireless controller C100 Unmounting file systems:
  • Problem
  • Updated 5 years ago
  • Solved
Problem Description: I have a controller
c100 in version 3.1 ,i have onli CLI session with serial cable .
The led status remains off
When C100 was started I try to do software
update ,but it failed and I can 't use GUI for configuration .
I can use only serial connection 9600 N8 1
Rebooting...
INIT: Sending processes the TERM signal
Stopping anacron: [  OK  ]
Stopping keytable:  [  OK
Shutting down console mouse services:
[  OK  ]
Stopping sshd:[  OK  ]
Stopping xinetd: [  OK  ]
Stopping crond: [  OK  ]
Stopping portmapper: [  OK  ]
Shutting down kernel logger: [
OK  ]
Shutting down system logger: [
OK  ]
Shutting down interface eth0:
[  OK  ]
Shutting down loopback interface:
[  OK  ]
Starting killall:  [  OK  ]
Sending all processes the TERM signal...
Sending all procmd: recovery thread got
woken up ...
esses the KILL signal...
Syncing hardware clock to system time
Turning off swap:
Turning off quotas:
Please stand by while rebooting the
system...
flushing ide devices: hda
Restarting system.
root (hd0,0)
Filesystem type is ext2fs, partition type
0x83
kernel /boot/vmlinuz ro root=LABEL=/
console=tty0
   [Linux-bzImage, setup=0x1400,
size=0x1101c6]
initrd /boot/initrd.img
   [Linux-initrd @ 0x1ffbf000,
0x2028e bytes]
HiPath Wireless Controller version 3.1.3.00.06
Unauthorized access is prohibited.
HWC login: root
Password:
[root@HWC root]#
[root@HWC root]#
I have remote connection
Contact language: Italian, English only
written
Photo of Ivo Treppaoli
Ivo Treppaoli
  • 70 Points
Posted 5 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Official Response
Unfortunately this product is not something that was supported/offered by Enterasys or Extreme. If you are looking for a comparable replacement to this product, you should contact gsola@enterasys.com directly to discuss your options.
Regards,
Doug Hyde
Sr Support Engineer
Extreme Networks
