Wireless CTP tunnel
  • Problem
  • Updated 4 years ago
  • Solved
We have Enterasys APs (3705i, 3710i & 3710e) attached to a C25 controller. They have a static IP and everything seemed to work fine but when I look at the Active Wireless Report, I can see that the tunnel duration on some AP's is lost. At first I thought they were resetting but they aren't. Out topologies are B@AP and the client is not loosing any service but that behavior is not ok. The firmware we are running is 08.32.03.0002.
Photo of Valdes, Victor Daniel
  • 80 Points 75 badge 2x thumb
  • frustreted
Posted 4 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Official Response
Hello,
One thing to check that we see come up from time to time that displays this type of behaviour would be speed and duplex settings. If you are plug the access point into a port that's 10/100 you should hard set both the switch port and the ap via the ap properties drop down box (default auto) to 100-full duplex. If the port is a triple speed 10/100/1000 the ap's auto mode should link up correctly at 1000-full.
-Doug
