Where can I find DHCP lease information on IdentiFi v10.11?
  • 2
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
With dhcp enabled on identifi V2110 controller running 10.11 code, where do i see the details of lease info?
Photo of Dean Ferraro
Dean Ferraro
  • 782 Points 500 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Dean,
VNS >> Topologies >>
click on the created topology and look for DHCP:Localserver and you can see the lease time by clicking the "configure" button.
Photo of ATK Suomenlinna
ATK Suomenlinna
  • 70 Points
how to clear leases in identifi (9.21.6 in my case)? ran out of leases, reduced lease time, but the now obsolete leases are not automatically cleared.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,004 Points 50k badge 2x thumb
You can't clear the leases via the GUI.
But you'd set the topology to "use relay" and any IP and save - then set it back to "local DHCP" - that should reset/clear the lease file.
Dean Ferraro
Very good Thanks Ron
ATK Suomenlinna
  • 70 Points
Thanks. Later found this also https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-delete-the-DHCP-lease-file-on-the-IdentFi-Wireless-Controllers basically it is possible to go to the shell level and edit the leases file. I would add to the How To that the default writing cycle of the dhcp daemon to this lease file is 5 minutes, and it is best to start editing after the next write is done so one gets full 5 minutes editing time.
