WLAN-Controller Topology-Group Loadsharing
  • Question
  • Updated 11 months ago
  • Answered
does anyone know, how the controller treat the end systems, when using a topology group in the VNS?
For example if we have a group with 3 VLANs, will he do round robin?
Haven't found anything in the documentation.
Best Regards
Chacko
Photo of Chacko
Chacko
  • 1,206 Points 1k badge 2x thumb
Posted 11 months ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Hi Chacko
If you are referring to the IdentiFi product these are the algorithms you can select in the global vns section:
• MAC-Based: This algorithm always assigns a client to the same topology within the topology group.
• Round Robin: The list is considered ordered; start at the top of the list. The next assignment is the
next topology on the list; wrap around at the bottom.
• Random Selected: Random number selected from a uniform distribution mod the number of
topologies in the topology group.
• Least Used: Assign a topology in the topology group with the least number of stations assigned to it
at the moment of assignment.
-Gareth
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi Chacko
Please note that the controller provides minimum support to use only tunneled topology groups (B@AC, routed).
Best regards,
Bin
