WLAN disable/enable script in NetSight 7
  • 2
  • Question
  • Updated 2 years ago
  • Answered
We have a goal of Enabling / Disabling a SSID based on a schedule. We want to use NetSight 7 with the new built in Wireless: WLAN disable/enable schedule script. Am I doing this right?
In the script. I edited the original script.
In the Overview tab I changed status to Enable. I then entered DIS-open as my SSID.
I did Save As and named it "DIS-open enable".
for the second script,
In the Overview tab I changed status to Disable. I then entered DIS-open as my SSID.
I did Save As and named it "DIS-open disable".
I click the enable script and click Run Script at the top.
1. Device Selection. I move the switches at DIS to the right as this is the only place DIS-open is available.
2. Device Settings. Needed options are already set.
3. Run-Time Settings. Under Task Information I choose Save as a task, I'll run later. Name this task DIS-open enable 6am-6pm
4. Verify. All looks fine.
Close
Go to Script Tasks
Click the Schedule Tab
Fill in Recurrence, Weekly, M-F, 6am
Fill in date and time, until August 2030, 6am 6pm
Fill in email info
Then repeat the Disable task
Is this all? Did I miss something?
Photo of rhaviland
rhaviland
  • 244 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
That looks correct to me .
Before you schedule the task you can try and test is as is - like "run now" and see everything is working as expected . Then Create one task per each action (task Enable and task Disable) , then schedule the task as needed.
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,804 Points 3k badge 2x thumb
Rhaviland, you mentioned switches? or do you mean the wireless controller ?
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,174 Points 50k badge 2x thumb
The mentioned view is for the device selection and lists all of them ... but you are right that this special script makes only sense for a WLAN Controller......
