WLAN guest portal configuration
  • Question
  • Updated 4 years ago
Hi, is it possible to create guest portal user with different bandwidth assignment
Photo of Frank Richter
Frank Richter
  • 340 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,846 Points 20k badge 2x thumb
As far as I'd see that is not possible with the controller build-in guest portal solution.
Frank Richter
what would be the best solution for this issue?
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
You could use internal captive portal or external captive portal and control the guest access via a RADIUS server. The role you return back from RADIUS can have different bandwidth limits assigned per user group. Something like A users in Gold, B users in Silver etc.
