WM3700 & Identifi AP Compatibility ?
  • Question
  • Updated 2 years ago
  • Answered
Have a client with this controller - but can't find info relating to the compatibility between the 37xx, 38xx AP's compatibility ?
Will the current gen APs work on the WM3700 ?  Are there limitations, minimum FW versions ?
thanks !
Photo of Dewald Botha
Dewald Botha
  • 674 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,442 Points 5k badge 2x thumb
Hi.
There are two wireless solutions from Extreme now on the market.
One is originaly Chantry -> Siemens -> Enterasys -> Extreme (often called IdentiFi). There was also period of time when Extreme was getting it from Siemens directly.
One is originaly Motorola -> Extreme
You can not manage APs from one by controller from other.
The AP37xx, AP38xx and AP39xx are IdentiFi => will not be managec by Motorola controller.
Is your controller originaly Motorola or Siemens?
Zdenek
Yes there are minimum versions = it is documented in release notes and manuals.
It is not the same for each AP from the same family = the 3801 and 3805 and 3825 do have different minimum versions
Dewald Botha
Hi Pala,
It is an Extreme WM3700 version 5.5.5.0-018R
They are currently using these APs : ap4600 - AP4610-ROW
But, these are EOS - so we can't supply new APs to them.  They need to add/replace APs - I am just trying to find what APs will work ?
Unfortunately you can not manage by WM3700 any of: AP37xx, AP38xx, AP39xx
Please contact local Extreme team to find suitable solution.
Zdenek
Dewald Botha
thanks.
