WM3700 wireless controller
  • Question
  • Updated 3 years ago
  • Answered
How to create same SSID with multiple vlans (apart from radius method) on WM3700.
I am using default profiles of both controller and access point.
ap model is 4610
Photo of Saiprasad Rao Rapolu
Posted 3 years ago
Photo of Chad Smith
Chad Smith, Senior Escalation Support Engineer
  • 5,620 Points 5k badge 2x thumb
Saiprasad,
How will the clients be placed into the different VLANs?
If you simply wish to load balance clients in different VLANs you can use VLAN Pooling:
or from the CLI:
L3L_K2_U41_WM1(config-wlan-L3L_dot1x_1)#vlan-pool-member 2202
L3L_K2_U41_WM1(config-wlan-L3L_dot1x_1)#vlan-pool-member 2203
Note: You must also make sure that all VLANs are added to the AP/WM uplink port and switch ports to ensure that the clients have connectivity on the VLANs.
Should the switch port contain both vlans 2202 & 2203 as tagged apart from ap vlan being untagged...... and what about the default ap profile should they carry both vlans as tagged......
(Edited)
Photo of Chad Smith
Yes, assuming you are locally bridging traffic at the AP and the AP mgmt VLAN is untagged, both client VLANs would be added tagged to the switch port and AP port.  If, the WLAN was tunneled back to the controller then the VLAN tagging would be performed on the WM uplink and corresponding switch port.
For the AP configuration, you can make the client vlan configuration changes either in the AP profile or in the device configuration.  AP profile would be more efficient so that it could be applied to multiple APs at once.
