WS-AP3705i Console Port
  • Question
  • Updated 2 years ago
  • Answered
We want to use AP3705i console port.
Can we configuration from console port of AP3705i? (IP, gateway, etc.)
to tell us ;
AP console port pin assignment , terminal setting
Regards,
Photo of kouichi ohtomo
kouichi ohtomo
  • 260 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,288 Points 50k badge 2x thumb
Hi, you'd set the following parameter via the console port to allow the AP to connect to the controller if you don't use an DHCP server...
- IP = cset ipaddr x.x.x.x
- subnetmask = cset ipmask x.x.x.x
- gateway = cset gateway x.x.x.x
- set controller IP = cset authip 1 x.x.x.x
to apply and save use..
- capply
- csave
The baudrate is 115200 - just use a the same console cable as you'd use for a router/switch.
kouichi ohtomo
Thank you for reply.
We were able to confirm that it can be set from the console port.
However, there was the discovery of 2 points.
1, console cable, in the Cisco console, was not a Enterasys console.
2,  It was required first to [cset dhcpc disable] command
** We have tested with firmware version "08.32.08.0002".
Regards,
Photo of juan romero
juan romero
  • 400 Points 250 badge 2x thumb
Is there a way to confirm configuraration a "show configuration" command or something like that?
Photo of James A
James A, Embassador
  • 7,432 Points 5k badge 2x thumb
There's "cget config" which is fairly comprehensible.
juan romero
Thank you very much, I'll try the command.
