WS-AP3865e Correct Position Installation on outdoor environment.
  • 2
  • Question
  • Updated 12 months ago
  • Answered
hello Extreme Community. I need your help. I am confused on how to physical install a WS-3865e  WAP model.
I need to install on a container yard with tall hangar (15 meters tall) my question is what is the best way to install this 3865e if vertical or horizontal for correct signal propagation. I got antennas WS-AO-5DPIN3 and WS-AO- 2DPIN3 installed for these APs.  I really appreciate your recomendation or a link to read and learn how to do it.
thank you so much.
Photo of Erik Ramos
Erik Ramos
  • 112 Points 100 badge 2x thumb
Posted 12 months ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,004 Points 50k badge 2x thumb
here a link to the installation guide...
http://documentation.extremenetworks.com/wireless/ap_guides/9034808-02_ws-ap3865e_installationguide....
I'd install the AP so the antennas are pointed up/down.
Also I'd make sure that the AP is installed not too high so he'd provide the best signals to the MUs > if all clients are located on the ground level it's not a good idea to install the AP on the hangar ceiling.
-Ron
Photo of Erik Ramos
Erik Ramos
Hello Ronald, thank you for answer. this is the way I have them installed..
(Edited)
Photo of Pascal Lurquin
Pascal Lurquin
  • 970 Points 500 badge 2x thumb
Because I don't see recommandations from other member, please find some infos from our experience :)
it seems to be too high: You have to look at the diagram of the antennas (distance, debit)
Vertical polarization is always better than horizontal
The best is to do a site survey ...
Be aware of the electrical lines (saw on the first picture)
Thanks
Pascal
