WS-C2960X-24TS-L
  • Question
  • Updated 3 years ago
Recently I bought the Cisco 2960-X switch WS-C2960X-24TS-L. It always automatic shutdowns when connecting to the computer, why?
Photo of merrysmith
merrysmith
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Gradelain Ngouni
Gradelain Ngouni
  • 480 Points 250 badge 2x thumb
the way your switch is behaving is quite strange. therefore,  i'll recommend a Firmware upgrade to the actual version. might help...
cheers
Gradelain
Photo of Tomasz Lubas
Tomasz Lubas
  • 534 Points 500 badge 2x thumb
It shouldn't act this way. How you connecting computer ? Keep in mind that extreme console cable is quite different than cisco ones. Use blue console cable, connect via com and look what happends.
Gradelain Ngouni
nevertheless how you connect the PC, using copper or console cable, the right or the wrong console cable, i do think that  the switch shouldn't  shutdown....
if you're able to use the console, then send us the output when it reboots...
Photo of Drew C.
Drew C., Community Manager
  • 37,350 Points 20k badge 2x thumb
Hi Merry,
This is a question that might be better directed to the actual Cisco support forum:  https://supportforums.cisco.com/
