X250e Configuration Fail
JeremyClarkson
Anyone had recent Issues with X250e switches and all the modules are enabling themselves.
I have had this on 4 switches now.
Thanks
15 REPLIES 15
JeremyClarkson
Ah yea now i see, i hadn't noticed this before. I was so used to the new release.
Im sure though that version 12.x.x did work at some point with show config show only non-default configuration. It just seems strange that when we swapped them for new X440 they worked a treat.
edit: yes 12.1 thanks!
Since you are being helpfull does extreme have a basic troubleshooting guide to follow using EXOS i usually just use the show command to find anomalies.
show port utilization
show port configuration
show tech... etc.
any help would be great.
Thanks
These are awesome! Thanks!
Drew_C
Valued Contributor III
You might also like the Extreme Networks Deployment Jumpstart.
Sure.... a few of themWe publish articles every day to GTAC Knowledge based on issues the engineers resolve each day, from customer inquiries around the globe.
The KB is continually improving and is a perfect resource to help you troubleshoot. Its also mobile friendly, so great if you're on the go. Just pull up a browser on your mobile device and the responsive design kicks in.
We're always looking to write new content, so if you don't find what you're looking for...let us know!
