X430-24p and summitlite- firmware problem
  • Problem
  • Updated 2 years ago
  • Not a Problem
When upgrad to summitlite- then it can't reboot.
Photo of Li Ping Hsu
Li Ping Hsu
  • 280 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,904 Points 2k badge 2x thumb
Please clarify whether the switch wont boot or reboot. Would you be able to provide the output of what is being seen so that we can investigate? Also, please let us know what version of code that the switch was upgraded from.
If the switch will not boot, as a troubleshooting step, please use the following to restore the image from the BootROM (if accessible). The previous version of XOS or should work using this procedure. This will at help restore the switch to a working condition.
Photo of Merab Katibashvili
Merab Katibashvili
  • 112 Points 100 badge 2x thumb
Okey but I have other question and I have Cisco 3650 L3 end two xos summits 430 24t connecting trunk connection. Cisco L3 say flopping extreme switch connecting ports to vlan 1. What recommend give me about that.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 12,754 Points 10k badge 2x thumb
Hi Merab,
I am moving this comment into a new thread for better visibility
Please reference the new conversation here: MAC move seen in Cisco switch connected to Extreme
