X440-24t fan operation temperature
  • Question
  • Updated 3 years ago
  • Answered
can anybody tell me at which temperature the fan in a Summit X440-24t starts running?
I can't find informations about in the datasheet or userguide.
In another thread it seems the the fan will start running at 48°C, but in datasheet the operating temperature is max. up to 45°C.
I'm confused.
Can you help me?
Photo of Peter
  • 736 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Zelnosky, Kevin
Zelnosky, Kevin, Employee
  • 1,104 Points 1k badge 2x thumb
Official Response
Here is a GTAC article that states what you have already hit on.  Looks like the fans do not start until you exceed 48 degrees.
I'm not sure about the data sheet listing 45 as the max, if you do a "show temp" on the switch, what range does it list?
