X440-48p switch does not boot till unplug and plug the power cable
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
I have a setup of more than 100 X440-48p switchs firmware 15.6.4.2.
There are two switches which (if the power cut off and return back) do not boot till unplug and plug the power cable.
Is there any advice!
Thanks in advance.
Photo of Husam
Husam
  • 1,272 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,524 Points 5k badge 2x thumb
Hi Husam,
I would suggest to open up a ticket with GTAC on the same, you can provide the "show tech" for initial analysis.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Wow....thanks for deploying 100+ Summit X440(s) Husam!
GTAC will help you get to the bottom of this.
