X440 Bootrom not responding to spacebar
  • Problem
  • Updated 2 years ago
  • Solved
Hello,
We are trying to reset the admin password of our X440 Exos switch.
The switch is not responding to the spacebar to enter bootrom. Do we have wrong bootrom?
Is there another (hardware button) to reset the complete configuration of the switch?
We have connected serial cable and we tried following programs: secureCRT , screen /terminal combination.
Kind regards,
Frank
Boot text:
Extreme Networks
Alternate BootStrap Image
Starting CRC of Default image
Using Default image ...
Extreme Networks
Default BootLoader Image
DRAM Post
Press and hold the <spacebar> to enter the bootrom.
Copyright 2003 - 2013 Extreme Networks, Inc.
Loading OS Image ...
Running Image ...
Starting ExtremeXOS 16.1.3b6
Photo of Frank Veen
Frank Veen
  • 492 Points 250 badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
Keep holding the spacebar until you get the prompt. Just hitting the spacebar a few times is not enough. Are you using a mac , then this article may apply.
https://gtacknowledge.extremenetworks.com/articles/How_To/howto-get-into-Bootrom-with-a-Apple-Mac
Also on some windows clients you need to 'up' the keyboard repeat.
Photo of OscarK
OscarK, ESE
Hello Frank, did this answer help ?
Photo of Frank Veen
Frank Veen
Hi OscarK,
Thank you for helping.
We are indeed using a Mac and after also contact with Gtac we found out that it was working with Windows/Putty combination.
Frank
