X440-G2-24p Fan Speeds
  • 2
  • Question
  • Updated 2 months ago
  • Doesn't Need an Answer
What is the go with the X440-G2 fan speeds. We have some of these switches in class rooms and cabinets in classrooms and they are so noisy. We also have some in one of our data centers and its at a much much lower temp, but the same fan speed?
Office Switch:
Events 2.14 # sh temp
Field Replaceable Units                    Temp (C)   Status   Min  Normal   Max
Switch                : X440G2-24p-10G4      90.20    Normal     0   10-100  110
Events 2.15 # sh fan
Slot-1 FanTray information:
 State:                  Operational
 NumFan:                 4
 Fan-1:                  Operational at 7440 RPM
 Fan-2:                  Operational at 7560 RPM
 Fan-3:                  Operational at 7620 RPM
 Fan-4:                  Operational at 7680 RPM
Data Center Switch:
Server Room Edge.1 # sh temp
Switch         : X440G2-48p-10G4        52.50    Normal     0   10-100  110
Server Room Edge.2 # sh fan
 State:                  Operational
 NumFan:                 4
 Fan-1:                  Operational at 7680 RPM
 Fan-2:                  Operational at 7680 RPM
 Fan-4:                  Operational at 7620 RPM
Server Room Edge.3 #
They're about 40 degrees apart but running the same fan speeds? I have read that <30 and they run half speed? Do they not ramp up on scale with the temperature?
Photo of David May
David May
  • 90 Points 75 badge 2x thumb
Posted 3 months ago
  • 2
Photo of Anton Sax
Anton Sax
  • 1,242 Points 1k badge 2x thumb
I had a ticket open at GTAC about the same issue.
Their response was that the temparature/fan level is normal
In debug mode you can see this:
(debug) TST2-X440G2-5.14 # debug hal show platform platformInfo
PlatformName: X440G2-24p-10G4
PlatformId: 138 Type: 1
HAL_SELF_SLOT: 1
HAL_AM_I_PRIMARY: 1
HAL_GET_NUM_MAC_ADDR: 1
MAC[0]: 00 04 96 9e 89 67
HAL_GET_NUM_IO_SLOT: 1
HAL_GET_NUM_FM_SLOT: 0
HAL_GET_NUM_SWFB_SLOT: 0
HAL_GET_NUM_IO_SWFB_SLOT: 1
HAL_GET_NUM_MSM_SLOT: 0
HAL_GET_NUM_TOTAL_SLOT: 1
HAL_FIRST_SW_CAP_SLOT: 1
HAL_LAST_SW_CAP_SLOT: 1
HAL_GET_NUM_FAN_SLOT: 1
HAL_GET_NUM_PS_SLOT: 2
=======Environmental Data========
Fan Slot: 1 State OPERATIONAL
Fan Part Info:
Name:
SerialNum:
PartNum:
Revision:    0.0
Flags:       1
FailureCode: 0
PowerOnDate: Mon Apr 30 12:59:04 2018
Fimware Rev:  BuildTag:
gridId: 0 Number of voltage line to monitor: 1
Volt: 12.00V  Watts: 5.00W
Fan#0: State: OPERATIONAL Location:
Fan#1: State: OPERATIONAL Location:
Fan#2: State: OPERATIONAL Location:
Fan#3: State: OPERATIONAL Location:
Odometer: not supported
Temperature: 0 Celsius
RpmLow 500 RpmHigh 22000
Fan1: 4440 rpm
Failed 0 FailedCount 0
Fan2: 4560 rpm
Fan3: 4140 rpm
Fan4: 4200 rpm
Fan control period: 5000 msec
Desired temperature: 30
Fan Power Level: 100 errorSum: 210000000
Power Supply Slot: 1 State: POWER_ON
Power Supply Part Info:
Name:        Internal Power Supply
SerialNum:
PartNum:
Revision:    0.0
Flags:       1
FailureCode: 0
PowerOnDate: Thu Jan  1 01:00:00 1970
Fimware Rev: 1.1 BuildTag: Turbine on 10/1/2004
Nominal line voltage: 120 V
Volt: 12.00V  Watts: 200.00W
Redundant Power Info:
Volt: 12.00V  Watts: 190.00W
Redundant N+N Power Info:
Temperature: not supported
(Range 0 - 0)
Fan Speeds: (Range 0 - 0)
InputVoltage: 0 V Current: 0 A
OutputVoltage: 0 V Current: 0 A
Eff : 89
Chassis Odometer: 24787800 sec
Num Card Type Supported: 2
    CardTypeName:
        X440G2-24p-10G4
        __UNSUPPORTED__
Reading phy version information for slot 1 gunit 0
  Phy version    : 0x00000000 (starting at port 25)
(debug) TST2-X440G2-5.15 #
the fan could go as low as 500rpm, but i never seen it like this!
the temparature shown is an addition of ambient + cpu
Photo of David May
David May
Seems silly that the only settings for these fans seem to be Off, Noisy or Screaming...
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,834 Points 5k badge 2x thumb
The X440G2 does not have "setting" for the speed = you can not set the speed.
The X440G2 does have linear fan speed = there is 255 speed levels. It should not be "off, noisy, screaming".
There were bugs in the firmware regarding the fan speed control = I suggest to check your firmware.
The fan speed depends on the PoE consumption and ambient temperature.
Photo of Anton Sax
Anton Sax
dear pala,
i am on newest version
TST2-X440G2-5.6 # show version
Switch      : 800616-00-09 1723N-42176 Rev 09 BootROM: 1.0.1.8    IMG: 22.5.1.7
PSU-1       : Internal Power Supply
PSU-2       :
Image   : ExtremeXOS version 22.5.1.7 by release-manager
          on Tue May 22 11:48:55 EDT 2018
BootROM : 1.0.1.8
Diagnostics : 5.12
Certified Version : EXOS Linux  3.18.48, FIPS fips-ecp-2.0.16
TST2-X440G2-5.7 #
And I have only 2 poe devices connected
TST2-X440G2-5.5 # show inline-power stats ports 1-24
                                STATISTICS COUNTERS
Port  State         Class     Absent  InvSig   Denied    OverCurrent   Short
1     searching     ------        0      46       0          0             0
2     searching     ------        0     193       0          0             0
3     searching     ------        0      46       0          0             0
4     searching     ------        0      46       0          0             0
5     searching     ------        0      49       0          0             0
6     searching     ------        0      49       0          0             0
7     searching     ------        0      57       0          0             0
8     searching     ------        0      48       0          0             0
9     searching     ------        0      18       0          0             0
10    searching     ------        0      15       0          0             0
11    searching     ------        0      13       0          0             0
12    searching     ------        0     180       0          0             0
13    searching     ------        0     218       0          0             0
14    delivering    class3        0       0       0          0             0
15    searching     ------        0     151       0          0             0
16    delivering    class3        0       0       0          0             0
17    searching     ------        0      27       0          0             0
18    searching     ------        0     136       0          0             0
19    searching     ------        0     242       0          0             0
20    searching     ------        0     189       0          0             0
21    searching     ------        0     237       0          0             0
22    searching     ------        0     242       0          0             0
23    searching     ------        0     101       0          0             0
24    searching     ------        0      68       0          0             0
the fans are always above a normal level:
TST2-X440G2-5.1 # show fans
 State:                  Operational
 NumFan:                 4
 Fan-1:                  Operational at 6180 RPM
 Fan-2:                  Operational at 6180 RPM
 Fan-3:                  Operational at 6180 RPM
 Fan-4:                  Operational at 6240 RPM
As the temperature is nearly maximum in a normal IT rack without ac:
(debug) TST2-X440G2-5.8 # !cat /proc/extr/temp
Sensor           Module Type  Driver        Temp     Tos   Thyst
mb-default            2    1  lm75         44.50   88.00   50.00
mb-hotspot            2    3  lm75         40.00   71.00   66.00
cpu-temp-remote       2    4  tmp435       50.37
cpu-temp-local        2    5  tmp435       36.37
(debug) TST2-X440G2-5.9 # sh temp
Switch         : X440G2-24p-10G4        89.78    Normal     0   10-100  110
I was told the temperature value is an addition of cpu temp + ambient temp
So in my eyes it is impossible to reach a normal value af 10 degrees celsius
the x440g2 is very noisy, we installed them instead of A2 and A4 switches. these were not that loud.
Photo of Tobias R
Tobias R
  • 60 Points
I run into the same problem. With 2 connected PoE Devices the fanspeed increase up to 10.000rpm. After disabling the PoE Devices, the fanspeed went down to 2.100rpm.
In my opinion, these switches are to noisy for any office enviroments and useless with PoE.
