X440-G2 DAC compatibility with Intel 10 GbE X520-DA2 NIC
  • 2
  • Question
  • Updated 10 months ago
  • Answered
Has anyone attempted to use the Extreme 5m DAC SFPP cable (10306) with an Intel 10 GbE X520-DA2 NIC?
Switchtype is X440G2-48p-10GE4 (16535), shoud work!
Our customer needs to verify compatibility.
Thanks,
Udo
Photo of Udo Stahl
Udo Stahl
  • 210 Points 100 badge 2x thumb
Posted 11 months ago
  • 2
Photo of Eric Burke
Eric Burke
  • 3,168 Points 3k badge 2x thumb
We don't have a client running this but I thought I'd share a reminder... Those ports will only run at 1gb without added licensing. Our sales team forgets that all of the time.
Photo of Udo Stahl
Udo Stahl
Hi Eric, thanks for this hint. The customer has a dual-10GB-lic running.
Photo of Udo Stahl
Udo Stahl
If anyone has tested an alternative 10GB SFPP NIC which is compatible, it would be helpful too.
Here are the supported NICs for the IBM server:
Brocade 10 Gb Dual-port CNA for IBM System x
Emulex 10GbE Virtual Fabric Adapter for IBM System x
Emulex 10GbE Virtual Fabric Adapter II for IBM System x
Emulex VFA II FCoE/iSCSI License for IBM System x (FoD)
Mellanox ConnectX-2 Dual Port 10GbE Adapter for IBM System x
Mellanox ConnectX-3 10 GbE Adapter for IBM System x
QLogic 10 Gb Dual Port CNA for IBM System x
Broadcom NetXtreme I Dual Port GbE Adapter for IBM System x
Broadcom NetXtreme I Quad Port GbE Adapter for IBM System x
Broadcom NetXtreme II Dual Port 10GBaseT Adapter for IBM System x
Intel Ethernet Dual Port Server Adapter I340-T2 for IBM System x
Intel X520 Dual Port 10GbE SFP+ Adapter for IBM System x
Intel X540-T2 Dual Port 10GBaseT Adapter for IBM System x
Thanks for some feedback,
Udo
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
The X520-DA2 is a very popular 10G card and so far has worked with everything I've used in our labs. I'm pretty sure I've also used a 5m DAC without an issue. I've got a few 3m cables in use with an X520-DA2 connecting to a variety of EXOS platforms.
(Edited)
Photo of Udo Stahl
Udo Stahl
Ok, then we will try out this NIC and I will post a feedback with the results.
Thanks
Udo
Photo of Udo Stahl
Udo Stahl
So, here the facts:
The customer is using a 3m DAC cable and it is working fine.
Thanks for all the replies.
Photo of Drew C.
Thanks for coming back to update us, Udo!
